NFExp
- Jun 18, 2009
- 77
I am working on a renovation at a 2-story church where the architect is removing the existing 2nd floor to create a volume space. The existing walls are 8" masonry and the reinforcement is unknown at this point but its assumed that the existing wall will need to be retro fitted... My suggestion would be to add steel columns and steel purlins attached to the masonry walls with steel angles and epoxy anchors.
I am reaching out to see if there are any other ways to retro fit the masonry worth exploring.
FYI
The walls are 22' high
The roof load is 1000plf
The wind load is 47.7psf (ultimate)
No seismic
Thanks in advance.
FYI
No seismic
Thanks in advance.
