Zoobie
Chemical
- Oct 22, 2002
- 193
I have been struggling with simulating (HYSYS) the sweetening of a 6mol% CO2, 2000 ppm H2S gas using 45wt% MDEA (operating at about 800 psig and 100F). Sweet gas has to be 2% CO2. The results that I am getting appear to be garbage. I am chalking this up to the fact that this is a tertiary amine used for bulk removal of CO2 (as per pg 21-10 in the GPSA data book, 10th ed.). I do not have a workaround for this yet.
After inputting my tower data I get CO2 stage efficiencies below 3%. This seems odd. Of course manually changing the efficiency makes a big improvement...duh. The H2S efficiency doesn't seem to far off...about 50%. This is for some ballpark estimates for max throughput through the unit but right now I don't think I am even in the parking lot.
Here are the questions that I have:
1) What would be a reasonable efficiency for CO2 per stage? 30%, more, less?
2) In the event the simulator does not satisfy my needs, what would be a reasonable mol/mol loading for CO2/MDEA in this sort of system?
3) What would be a reasonable BTU/gal for the still reboiler? GPSA book states that 'requires only a modest heat input'. Is this substantially below 800 BTU/gal?
Thanks for any help you can provide.
