engstructural
I have been looking at a wall already built. The lower 3.0m high section is a gravity boulder retaining wall with a 2.7m high anchor block and geotextile wall built of the top of it. The anchor wall seems to be adequate but I cannot prove the adequacy of the lower gravity wall when taking into account the total retained height if 5.7m (I added the additional load as an increased surcharge to the lower wall.)
1. Where we have space in front of the wall would it be adequate to place fill material compacted in layers to the top of the boulder wall with a slope down of 3:1?
2. If this is done I assume the lower wall can be ignored, is this correct?
3. Where the is only a 600mm gap between the wall and the property what is the best way to strengthen the wall (re-build/Sheet piles/ Bored piles)?
Thanks for any comments.
