reload a part with same name
engmechs
80
Hi all,
I am working on an assembly with numerous parts, & for a part I want to reload it with a modified version, but same name, at a different file location. How can I do that? I tried to replace it but with no luck. Please advise.
engmechs
When finished updating, save over the old one. It's always a good idea to work with the original, not a copy ... or use PDM.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
ctophers method is the simplest. When the assembly is re-opened you may receive a message stating that the internal ID of the component does not match. If you do, just click OK to accept the new part.
If you want to use Replace while the assembly is active, you will have to change the name of the new component.
[cheers]
engmechs,
Anoter method is to suppress the part in your assembly (as long as you only have a few inserted into it), open the new part up, then unsuppress the part in your assembly. You may get the message CorBlimeyLimey mentions but follow the same advice. I would also now delete the old part if it no longer needed (especially if the part is in the same folder as the assembly as the next time you open the assembly up, it will find the old part [unless you have search paths set up]).
Regg
Thanks guys for your advices,
My problem is that the parts are dimmed out (suppressed state), & I tried to unsuppress the part (the dimmed part)by using the resolve method, there is no response! Is this the normal ?
engmechs
Try to unsuppress it when you have the part open in its own window. Generally, when a part is suppressed and won't unsuppress it's because SW can't find it. By having it open in its own window, SW will recognize it and open it in the assembly.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
This will work too .....
With the assembly closed, delete (or move/rename) the original part file.
Then when you open the assembly, SW will prompt you that the file cannot be found and will allow you to browse to the new file location.
Remember...
[navy]"If you don't use your head,[/navy] [idea]
[navy]your going to have to use your feet."[/navy]
Thanks guys for your wonderful comments.
engmechs
