Sirius P.Eng.
Chemical
In trying to determine an accurate latent heat of vapoourisation for an LPG tank exposed to an open pool fire, I recently came across this procedure (see link below) to determine the latent heat of vapourisation for multi-component mixtures using Aspen HYSYS.
Title: Determine Latent Heat for Multi-component & Relieving Area using Rigorous Method in HYSYS
I have not been able to reproduce/follow the procedure because process steps 1 and 2 are unclear.
Anyone with experience on such rigorous methods may correct the procedure if required or explain clearly what was meant.
Alternatively, if there are other rigorous/highly accurate methods (apart from a dynamic simulation of course) please share.
The LPG Mixture I am looking at has the composition in mole percent:
Propane: 60%
i-Butane: 10%
n-Butane: 30%
I have ruled out using the latent heat of hexane (115 kJ/kg) as suggested in API 521 because it would result in a high relief load.
Propane: 60%
i-Butane: 10%
n-Butane: 30%
