Relief Valve
bb3511
1
Need help sizing a relief valve for a 70K liquid nitrogen tank......any help would be greatly appreciated
Not enough information:
What is MAWP of Vessel?
What is supply pressure?
What is supply volume, flow rate?
J. Alton Cox
President
DeLuca Test Equipment
What information are you looking for?
I assume you don't know where to start (and in that case, I seriously do not recommend you size this PSV on your own unless you have someone qualified to check your work). API 520 would be the first place I would recommend you review assuming you have someone there who can help you with any questions.
