ReliefSystemEngineer
Chemical
Hi All,
Should their be a Relief Valve after a Steam Letdown Station on a Steam Header(in general) ?
We are planning to merge a 35#Steam Header into an Abandoned 15#Steam Header. The idea is to install a 35# -15# Letdown station on the 18" 35#Steam Header. The 15# Steam will be used by various equipments and heating systems in the area. All the equipments have individual relief valves which are set @ 25 psig and all the equipments & associated piping have a design pressure of 50# or higher. Currently, the other end of the 15#Steam Header receives steam from a 175# -15#Steam Letdown Station. Their are adequate size relief valves after this 175#-15# Steam Letdown Station.
Should their be a relief valve after the 35# -15#Steam letdown station(for the above situation) ?
Any help, guidance & tips is greately appriciated.
PD.
PD.
