jamesbanda
Chemical
Dear sirs.
i'd like some guidenace on two cases i've encounted.. (and validate my methods)..I appreciate this is a bit techy.. i've not show all the methods i've used as i dont want to bias responsces..
1. Relief pressure close to critical pressure.
On this cases the latent heat approaches zero near the ciritical prsesure so you end up with a very large relief valve. This does not seem quite right to me. am i missing something in the anaylsis ?
to date, on projects i've elected to take a lower relief pressure and small valves on some occasions.. but that does not quite sit right..
2. Relief pressure above critical pressure but normal case below critical pressure..
on this case i'm struggling to size valve.. do
A) Treat it as a vapour only for determining as if the system is just above ciritical temp
b) treat as a liquid ?
and is there good guideance on this..
