Hi guys.
As we know, if a DC current applied into a coil, enery will be needed to build up the magnetic feild surrounding the coil, once that is done there will be no energy needed and no energy consumption (neglect the coil resistance )- I hope I am right.
Now in case of a relay coil operates against its spring to pull up its contacts and keep them closed, there will be energy needed to operate aginst the spring while the contacts are moving to the close position.
My question now, what will be the situation after the contacts closed - Is any anergy is needed to keep the contacts closed against the spring ?
Thanks in advance
Thanks in advance
