Relay drive for -12V and GND controlled with the positive voltage 2
homoly
100
Currently I am adapting some additional modul to the existing design with dual +12V and -12V supply were the +12V is no more sufficient enough to drive the 160 mA power relay I need, so I would like to use -12V and GND to energize the coil. For driving the switching component I have 12V and 0V for my disposal from CMOS logic. For this reason I would like to ask you if you have some real word proven circuit able to solve this problem. My first ideas are to use P channel JFET driving MOSFET or using inverting OPAMP with -1 gain driving NPN bipolar transistor ( -12V on C and 0V on E ) but before eventual reinventing the wheel I would like to know the opinion of someone with more experience in electronic design than I have.
Exactly, I would like to energize the coil from -12 and GND rail and the switch controling the coil energizing should be controlled by CMOS 4001 NOR gate output supplying 0V or +12V.
Easiest and cheapest is probably an optocoupler driving a transistor driving the relay.
Benta.
Using an opto isolator is always a safe bet. Another choice is to use a 15-20V zener with a series resistor driving the base of PNP transistor with the emitter connected to -12V rail. A FET would also work with the zener being 12-15V.
Thank you all for the response. The optocoupler seems to be the most "painless" solution so I will start on the prototype with this one.
I am disconnecting the 230VAC / 40A power supply with 2 NC contacts of the relay and the coil is driven by 12VDC.
OK. I was going to suggest going straight to PhotoMOS solid state relays but for the service you've just stated it would not work well.
Sorry.
Carry on.
Keith Cress
kcress -
Keith, thank you anyway for the suggestion. At least in different application I will have one more idea :).
