Hello all,
Would appreciate some guidance here.
I have an air compressor compressing ambient air to 3000 psi into a 425cu-in tank. I have the volumetric flow rate at the exit. If I was looking for relative humidity, dew point, and moisture content/accumulation at the exit, how would I go about doing so.
The air would then be expanded from 3000 psi to 600 psi, how would I get the same information again?
I'm trying to evaluate the size of the moisture separator and heat exchanger needed to keep the system out of moisture by getting those values.
Thank you in advance.
