Noopur
- Aug 19, 2002
- 35
I have a question regarding the deflection of curved girders. The bridge I am working on:
Has skewed supports (not radial)
Supports are not parallel to each other
Span is a simple span (167’ longest girder, 158’ shortest girder)
The supports are skewed such that the outer girder is actually the shortest. And the girder on the inside of the curve is the longest.
Radius of all girders is 605.22’
I am getting larger deflection (8.6”) for the outside girder and about 5” less (3.7”) for the inside girder.
For a normal curved girder bridge with radial support, it is understandable that the outside girder (longest) would deflect more. But for this bridge, with the outside girder being shortest, is this still true?
Does anybody of you had a similar situation like this. I am designing a curved girder bridge for first time and really do not know where to look for answers.
Your valuable input from experience is much appreciated.
thanks.
Njain
Noopur Jain
Bridge/Structural Engineer
thanks.
Njain
Noopur Jain
