Relationship between differential pressure and flow 2
ris2
Chemical
TT
What formula is used to calculate flow using differential pressure in pipes? Are any other variables taken into consideration?
Thanks.
Darcy's equations is usually used. There are other variables:
viscosity, density, pipe roughness, pipe diameter, etc.
maybe you should take a class in fundamental fluid dynamics?
Best regards Morten
