Hello gents,
Sorry for my poor English, I will do my best to describe my case I have to resolve.
I have a steel ring devised by 4 pieces I need to tighten them around a concrete column.
The 4 parts are bolted to one another (say 6 bolts between each part).
The height of the ring is (say) 500 mm = 20 inch
The ring or called bracket supports a vertical force/ piece (say 20 Ton/ part).
I need to know how torque I need to apply to tighten the bolts to be sure that the bracket is tighten enough to transfer the vertical force by friction to the column. Besides, The vertical forces are offset (1m), which means I have Vertical forces plus a moment.
I will appreciate any help
Many many thanks
Many many thanks
