We are having a debate at work. We have a process where the absolute humidity is measured. They want to predict the relative humidity. Some are claiming you don't need to know the system pressure to find RH. I say no - absolute humidity is a mass ratio only, but RH depends on system pressure, because the partial pressure of the water vapor must be known to calculate RH.
Does anyone disagree? Is it possible to predict RH from AH directly without any other conditions known?
