wsmith22
- Nov 9, 2005
- 67
Is there a standard location to orientate the vent hole on a reinforcing pad for ASME Section VIII, Div.1? ASME B31.3 says to put it on the horizontal centerline (not at the crotch). API-650 same thing. The Dennis Moss Handbook says at least 45 degrees from horizontal centerline. My shop says on the vertical centerline of the shell. Does it really matter?
Moss also indicates that an air test should be done on the reinforcing pad. My understanding is that this has never been the intent of ASME Section VIII, Div.1 and is not required.
Thank you,
Wes
Thank you,
Wes
