Having read some papers on the design of deep beams (span/depth ratio < 2.0), the design guidance given is that the beams act as strut/tie structures. A compressive strut is formed from the load on the top of the beam to the supports at each end, and there is a tension zone running along the bottom of the beam acting as a tie.
If reinforcing the beam using rebar, it is advised that the main bars are placed near the bottom of the beam in the tension zone AND additional horizontal rebar is placed in the web of the beam to prevent the struts bursting and to prevent shear cracks running top to bottom of the beam by intercepting the cracks with this additional rebar.
I am considering using steel fibre reinforcement in place of conventional rebar to give me a reinforcing presence throughout the entire beam depth and this may prevent the bursting and shear problems occurring. has anyone attemptd this?
Andy Machon
Andy@machona.freeserve.co.uk
Andy Machon
