kslee1000...I appreciate your willingness to take my comments at "face value". If you check the respective ASTM requirements for rebar (ASTM A615) and steel shapes (ASTM A36) you will find that there are essentially no chemical restraints placed on rebar; whereas, A36 has specific chemistry requirements to control the metallurgy. Further, rebar is allowed to have less ductility, as measured by elongation, than mild steel shapes. Rebar is required to have a minimum elongation of 12 percent, while A36 steel has to have a minimum elongation of 20 percent.
What this means, at least to me, is that the controlled metallurgy of the mild steel shapes provides much greater predictability of its properties. It is weldable without significant limitation as to process, filler metals, and pre-weld/post-weld thermal conditions (except for very thick sections). Conversely, rebar has limited weldability, specifically because of its lack of controlled chemistry.
Sorry to ramble on....I just wanted to be clear about the source of my comments.
