MegaStructures
- Sep 26, 2019
- 376
I am recently interested in FEM for reinforced concrete structures. I’ve done some concrete design using code based software such as RISA, which uses plate elements with linear material models. I looked around a bit for some research that shows the difference in accuracy between these linear models and what I assume would be a more accurate non-linear model, but surprisingly I didn’t find much. There’s certainly research out there, but not quite as much as expected, or as definitive.
As a “fun” topic I wanted to know what others practical thoughts are on the differences in the analysis types. What would be the major advantage of using a non-linear material model instead of a linear one? What type of analysis would absolutely require a non-linear material model be used? In a more extreme scenario when would it ever be necessary to to take on the extremely academic approach of modeling non-linear concrete material AND physical reinforcing bar. I could imagine that a dynamic analysis might require a non-linear analysis such as a progressive collapse, or blast model, but is it ever necessary for a static load, or a quasi-static load where forcing frequency is not static, but far away from the structures natural frequency, suppose a wind load, or any live load could fall under this category.
I would be interested in research showing quantitive differences for the two methods compared to actual test results.
