I understand more now, you can't think the rod needs to be half the diameter of the cylinder, I have to figure surface area. (duh) The cylinders I have now are 1 1/2" with a 5/8" rod, they came with the pump, so I assumed they were the right ones, ( been there before) I have a 3,000 PSI pump, 1/4" fluid lines and the flow is very low, (30 seconds to extend 32") also I have no way to measure either the flow or pressure. With this configuration I figure I only have approx. 921 lb. pressure on the extend cycle, (not enough) I would like double that. I figure the ideal cylinder would be 1.25" with a 7/8" rod that would give me approx 1800 lbs. in both direction. I don't see any cylinders out there that are this size, I smell expensive and I need three of them.
This help is really appreciated
Ray D
