New here, hello, a google on my topic brought up hydromech's thread here somewhere. hydromech seemed the right person for the job. I would like to know if you could have the following hydraulic setup.
A 10-15mm diam and say 100mm long cyclinder and piston (piston 1, lever A) provide pressure like say a motorcycle levered hydraulic brake circuit.
The exit pressure/fluid line is a tube exiting perpindicular to the said cylinder. At the other end of the cylinder, opposite end to the the levered piston, is another piston 2, its lighter spring loaded function is fluid pressure release/moderation.
So I'm imagining in response to force on the lever A which pushes the piston 1, there is then an exit pressure which climbs and then plateaus (as piston 2 retracts in response to pressure).
The force on the piston 1, from the lever A, is spring resisted, but this lever, if given enough force, will move sufficiently to mechanically (via more levers ...'B') exert negative pressure on the pressurised circuit. (say this levers B system connects to a piston 3, acting on the cicuit)
So the system is imagined to have an exit pressure, in response to increasing input lever pressure, that initially increases in pressure, plateaus, and then drops off to zero .
I imagine it compact, which is why try to have one cyclinder providing two components to minimise weight and space, If it weighed a lot more more than say a motorcycle brake front brake reservior it wouldn't be so viable.
Apart from it being potentially completely unworkable (I dont know)
Any thoughts on that very much appreciated, not sure if I should continue to imagine this one or not.
Scott.
Scott.
