Hi Friends,
What is the minimum sheet metal thickness for doing a thread tapping inside a drilled hole, which has to bear hanging loads?
I am designing a mounting bracket made of 304 Stainless steel sheet of 3mm thickness.
Is it possible to do tapping in 3mm thickness sheet, and if not self clinching nuts (PEM Nuts) are the only way. Or is there any other way to create internal threads?
Please give suggestions.
