This procedure can at times be confusing/involved if you're not familiar with basic practices typically used for surface modeling. The following are the general steps to follow as each model can be a little different, depending on how the surfaces are modeled prior to converting the surface model to a solid model. It's also a good idea to be aware there are usually more ways than one to get from point A to point B using NX.
Create and, if necessary, trim surfaces to completely enclose a volume (meaning the surfaces are water tight) then use the Sew command to sew the surfaces together. In order for this to be successful, the surface edges must be less than or equal to the modeling distance tolerance. NX will typically flash "Solid Body created" in the Cue/Status line if the Sew successfully converts the surfaces to a solid body. Alternatively, you can set your preselection filter to Solid Body and hover your mouse over the surfaces - if they highlight, you know you have a solid. You can also hover over the body and wait for the 3 dots to appear, select the body and see if Solid Body appears in the Quick Pick menu that pops up.
Tips:
[ul]
[li]When performing the Sew command, if you click Apply rather than OK, NX will highlight all non-sewn edges which makes it a bit easier to see if you have any unwanted gaps between surface edges.[/li]
[li]Examine Geometry will also display gaps between surface edges after using Sew (Sheet Boundaries -> check Highlight Results).[/li]
[li]I recommend running Examine Geometry (Set All -> Window select around your entire surface model but do not include any curves or other construction geometry) before using Sew to check all of your surfaces in case you may need to fix any issues with the surfaces before creating a solid body. Repeat Examine Geometry as needed and at least when the model is 100% completed and fix any major issues (Misaligned, Consistency, Self-Intersection, Spikes/Cuts).[/li]
[/ul]
Tim Flater
NX Designer
NX 11.0.1.11 MP8
GM GPDL 11-A.3.4.2
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
