refresh and freeze-ups
innov
Industrial
Sep 9, 2005
36
Hi, I'm running a network version of Solidworks on a 4200 Athlon 64 X2 Dual core processor, 2 gb ram, and an ATI FireGL V3100 video card; and a 1900 X 1200 resolution. I'm having screen refresh problems (mostly when I'm zoomed in a good ways) and from time to time, also 5-10 second freeze-ups (seems pretty regular, though it happens more when I'm into in-context editing). I've watched the processor load monitor, and it doesn't appear to go over 40%.
I've heard the resolution I'm using isn't supported by Solidworks....If so, is there some kind of fix? please help
Thanks,
ps. I'm using SW '06 SP 0
Does it happen if you change your resolution?
Otherwise, I noticed similar artifact and disappearance problems in a separate thread with my FX-1400. You're not experiencing those sorts of symptoms are you?
Jeff Mowry
Reason trumps all. And awe trumps reason.
The refresh problem seems to disappear when I change the resolution, but not the freeze-ups, and also the occasional crash.
I don't get it, this is a new system, why should it cause me any problems?? The biggest assemblies I'm working with have at the most 30 parts, about half of them created in-context....
There could be many reasons for the freeze-ups or crashes.
Can you open up all the parts separately.? Are they all fully resolved (including all configs). Same for all sub-assys.
It could be a network problem or a bad stick of RAM or a faulty video card. (faq559-1058)
Are you running the video card driver recommended by SW?
[cheers]
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
