EmmanuelTop
Chemical
Has anyone seen this type of control on amine regenerator towers?
The basic concept is that the ARC (Advanced Regulatory Control) will be used to calculate the quantity of acid gas absorbed by circulating solution (kmol/hr). Reflux flow will also be calculated and expressed in the same way, so that the ratio Reflux/Acid Gas can be used as the primary controller loop cascaded to fuel gas flow controllers on regenerator heaters.
It seems that the operators find conventional control scheme (regenerator overhead temperature cascaded to fuel gas flow controllers on amine heaters) rather difficult and unstable - probably due to significant lag time between the action (change in T) and the response (firing the heater).
Can someone with field experience give his thoughts about this subject?
Thanks,
