Refining mesh size
  • Thread starter Thread starter mit_joel
  • Start date Start date
M
mit_joel
Guest
Does anyone know how to change the resolution of the mesh in Pro/Mech Structure? My results models sometimes have a bunch of lumpy elements instead of nice, pretty small ones.
Use AutoGEM>Settings>AutoGEM>Limits
You can also use surface & volume regions around areas of interest.
Of course with the p-element approach, you'll always have bigger elements than traditional h-element codes. Check your convergence, you might not need to refine the mesh.
