Referenced document undermines IBC requirement?
JAE
We came across a philosophical question about codes the other day. Here’s the issue:
There is a section in the IBC that references a document that deals with design of storage racks
(found here: RMI Spec link)
This is a document that is directly referenced by the International Building Code (IBC) in a section on rack design (don’t remember the exact IBC section). In chapter 35 (the IBC reference chapter) they refer to the document as well.
The IBC section states that racks SHALL be designed per the RMI Specification.
When you go to the RMI spec and download it (free at the link above) you find within that it goes out of its way to disclaim itself. It states that it is entirely a voluntary document and that it should be considered as a guide.
My question:
[red]If the IBC says you SHALL design to a referenced document, and the referenced document says you DON’T have to design to it, which is correct?[/red]
I see it as either of two options:
1. The IBC SHALL over-rides the RMI’s “voluntary” statements.
2. The IBC says you SHALL use the RMI for rack design and that word SHALL means that everything within the RMI is true – even the “voluntary” aspect of it.
What do you wise folks say?
