chino101
- Jan 7, 2003
- 4
Hello all,
I’m a intern engineer at a new combined cycle power plant. I’ve been recently assigned the task of evaluating the performance an installed plate and frame heat exchanger. One of the biggest problems with this plate heat exchanger is that it has the tendency to foul up relatively fast on the cold fluid side since we are using brackish water. The hot side is clean closed cooling water so there is no problem there. But what can be done to minimize the fowling of the cold fluid side? I have gotten the suggesting that increasing the flow rate on the cooling side would be able to minimize the fouling, do you guys have any other ideas or experiences with plate heat exchangers that you’re able to share with me?
Thanks in advance.
Thanks in advance.
