Hi all.
I have a heated body roughly 35 cm cubed. (14" cubed) with a steady surface temperature 50-60C and it seems to be loosing heat at about 2 kW in 20C air. I wish to reduce this heat loss with insulation. I am considering an insulated jacket of exp. polystyrene and I am considering a cylindrical outer shape to reduce surface area.
Is the cylindrical outer case a valid idea?
How would I model the thermal losses?
I am afraid I am not much of an analytical engineer. However I only a rough idea in order to confirm I am going in the correct direction.
Many thanks
Many thanks
