reducer nozzle
anolan23
54
Instead of a straight pipe as a nozzle, could a concentric reducer be used as a nozzle? If yes, when performing nozzle thickness requirements of UG-45, which diameter would be used? HELP IS HIGHLY APPRECIATED
anolan23, 1), yes, although it might be necessary to restrict the limit of reinforcement along the nozzle axis, depending on dimensions.
2) Ask yourself, "If I base UG-45 thickness on the small diameter, and the large diameter doesn't make, what do I do?" I'd think the answer would be obvious :)
Mike
Thanks for your input!
Luckily I am exempt from reinforcement UG-36(c)(3).
I would base it off the larger diameter one because I know that a smaller diameter pipe is stronger
Do you know if the reducer needs to have one of the standards as listed in UG-44?
I would suggest putting a straight pipe section before the reducer. So shell -> pipe -> reducer -> weld neck flange (or straight pipe and slip on). It makes things easier for the welding. I am not 100% positive that you can weld a reducer straight to the shell, but sntman didn't bring it up so I am assuming code doesn't have an issue. Even so, I am assuming the nozzle is quite small, since it is exempt from UG-36 reinforcement calcs, so the extra cost for a small straight section should be minimal.
