Basically when you create a part in context like that it references the assembly for the things that you used to help define it.
What you need to do is open the part in its own window and edit the features of the part to eliminate the external references. This will make that part stand on its own two feet (if you take my meaning)
Lets use a simple example...
I have a plate in an assembly and I created a new part in the assembly by starting a sketch on the face of the existing plate, converting the outside edges, and the holes in the plate as well. Then I extruded it to some thickness.
What we have just done is create some external references that refer to assembly for information.
1 The sketch entities have external references to the outside perimiter of the model edges, and also the edges of the holes.
2 (possibly) the sketch plane refers to a face of the plate in the assembly... (note this would only happen if we inserted the model on the origin, and then while in edit part mode, picked the face of the existing plate then opened a new sketch)
Lets say that both items 1 and 2 are true.
To get rid of the external references we would open the part and right click in the feature manager and select "List External references". This will launch a dialog box that will list every in-contect reference we have along with its status, and what type of feature it references.
Pay attention to what features, and entities are being reffered to.
Next (in the case of the above model)
We edit the features to eliminate those references.
Case 1: we edit the sketch and remove the "On Edge" relationships on all of the sketch entities. A quick way to find external relations is to use the display/delete relations tool, and set the filter up top to say "defined in context" Then delete the relations. Next we need to "rebuild" the relations in the sketch locally, by creating new relations via dimensions or geometric relations, etc.
Case 2: We need to re-define the sketch plane and use one of the system planes, or perhaps a user defined plane. to take the place of the face of the original plate we sketched on while in the assembly.
As you follow this procedure, you will notice that you will have less and less "->" signs showing. Ideally we want those to go away. Edit the part as you need to, to eliminate all of them. Now the part will stand on its own.
Hope that helps
Jon
jgbena@yahoo.com
