Apr 1, 2003 #1 J joeljkp Guest I recieved an IGES geometry of a rather complex body. I need to be able to apply a dimension (an angle) between two faces so that I can respecify it easily later. How do I do something like this?
Apr 2, 2003 Thread starter #2 A adicar01 Guest IGES geometry is blind, u can not redefine dimensions (angular or linear.
Apr 2, 2003 Thread starter #3 G gurveen Guest from the setup menu you can create ref dim which you can show in your model but you cannot modify it
