We make a Class 8 rear dump trailer, full frame. A customer is having problems with the trailer dumping red clay. The trailer goes to 43 degrees, as designed. The cylinder has no issues going all the way up. The trailer has a HMW Liner. They are working in the South.
They pulled the trailer to the manufacturing plant. When the trailer was at 43 degrees, we could see a lot of red clay still in the dump body. It pretty much covered the floor and the radius corners. And, none of it moved when it articulated up to 43 degrees. The customers says they have men going into the trailer and manually dumping.
The question is, what are our options as an engineer to fix this for the customer? Someone suggested a vibrator kit. Would that help? Our initial thoughts are that because of the red clay, and it is sticking to the liner and body, it probably won't fix the issue. We are looking for options to solve this issue.
Thanks,
Thanks,
