What do you do with the RO reject stream?
At risk of sounding obvoius, audit the demin plant (or softener, whatever it is) to understand it better first (eg: quality of each waste stream as regeneration progresses .. online conductivity data would provide insight). Make sure the demin plant is 'tuned up' (using the right amount of water and regenerants (NaCl or H2SO4?) in the first place, etc). Gary has certainly identified good opportunity ... commonly practiced where water is highly valued, so it is proven good opportunity at that!
Sounds worth pursuing. Good luck.
