i asume that you mean a tank holding water (or fluid) ... then the stiffener provides bending stiffness for the tank face ... a plain flat sheet is going deflect significantly out-of-plane. so then it sounds like a beam with a running load that's constant (well almost, i guess) ... and the four sides of the face react the out-of-plane pressure load (don't forget there's a component of load form the other faces too). i'd suspect that the upper edge would react about 1/2 the lower edge reaction (just by considering the triangluar loading from the fluid) and the side edges would also support some of the load (depending on the geometry of the face.
