Sep 25, 2003 #1 buck2 Mechanical Joined Sep 9, 2003 Messages 2 Location US Is their a website that lists the basic recommended tightening torques for metric and inch socket head cap screws into alloy steel?
Sep 25, 2003 2 #2 carburized Mechanical Joined Jun 5, 2003 Messages 36 Location US Try this site http://www.fandisc.com/tti.htm Ravi Upvote 0 Downvote
Sep 25, 2003 2 #3 unclesyd Materials Joined Aug 21, 2002 Messages 9,819 Location US I wouldb be very careful using torque tables. They are only guides to be used when conditions are known and the match the preload needed for you application. If you are not familiar with bolting go to a site like: http://www.boltscience.comThey have an excellent tutorial on bolted joints. I would recommend getting familiar with fasteners and bolted joints. If you are familiar with the process of bolting here is a site that has several calculators available on line. http://www.martindalecenter.com/Calculators4_2_MechSZ.html#MECH-TOR Go down to Torque and you will see several calculators the may be benefical. If the joint is very complex or involves safety get help. Upvote 0 Downvote
