recommended network files
jrpugh
We just purchased COMPRESS and Coster and I am looking for a recommendation for a network installation of common files only. We want users to run the software on their local machines but need to ensure that files such as the Coster database tables and templates that have been updated or modified are available to all users.
Does anyone have a recommendation for this?
Thanks in advance.
Jim P
I suggest that you contact Codeware technical support directly at support@codeware.com. Or use the web-based form at
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
Similar threads
