I'm not an engineer, more of a demented tinkerer...
That said, I am planning a supercharger set up using a Eaton M62 on a V6 Mazda KL 2.5L that requires a drive extension shaft. I'm thinking of using 2 bearings, at the pulley side of the shaft, and another support/line up bearing at the other end before the coupler. The greatest stress will be at the pulley support (planning on using a stock belt tensioner) and I would like to be able to support a shaft rpm of 15k+, while being able to live in an underhood environment.
I've looked at some of the greasable pillow block types and just came across the Pacific-Bearing 'Simplicity' line of mounted linear/rotational self-lubricated bearings but don't know which would be the most dependable/efficient.
Any advice/recommendations would be greatly appreciated.
