crjones,
That is an interesting observation. I've found that multi-stage recips
really don't like changing suction conditions and I've found that a combination of unloader valve and changing rpm to allow a flooded screw to operate over a wide range of conditions.
The problem on multi-stage recips is that a reasonably small change in suction conditions will be magnified 3-5 times in the second stage and Ratio
2 times on the suction side of the third stage--a clear opportunity for a high-temp trip and/or a serious rod-load problem.
For example let's assume you have a 3-stage recip set up to take air from 40 psig suction to 1,600 psig discharge (27 ratios, 3 per stage). If the suction drops to 20 psig then the frist stage discharge drops from 150 psig to 90 psig. This drops the second stage discharge from 486 to 300. Now instead of the third stage going from 486 to 1,600 it has to go from 300 to 1,600 (5.1 ratios). The result is that third stage discharge temperature goes from around 290F to 418F (assuuming 90F out of the interstage cooler). On most compressors that is the difference between running and being down on a high-temp trip. The actual dynamics are far from being this simple, but it is quite common for a properly set-up machine to take nearly all of a suction-change in either the second or third stage.
On the other hand if you are doing 27 ratios with a flooded screw (say -3 psig to 300 psig) and the suction drops to -6.6 psia (to get to the same 39 ratios in the earlier example) then the result will be to use 30% more horsepower, but the machine shouldn't see high-temp trips.
David Simpson, PE
MuleShoe Engineering
The harder I work, the luckier I seem
