Reciprocating Vacuum compressor
rock3x
9
In my firm we are using Reciprocating Vacuum compressor by Ingersoll Rand.The problem we are facing is the continuous repair due to the failure of our brass bushing in connecting rod.From net surfing i came across some alternatives like SAE 863 bronze,C954 Aluminium Bronze and Ampco18 Bronze,in this which one will be preferable or is there any other material is there.Also in crank shaft we are using Stainless steel bushing.Is it require any change.Which oil will be preferable.
Expecting positive replay ASAP
Rock,
I was starting to answer your question then I noticed your last line and deleted my response. Good luck with that whole "Give me free consulting ASAP" thing.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
I would suggest that you talk to Ingersoll Rand.
Best regards
Morten
Hai,
zdas04 (Mechanical)
I didn't mean to hurt your feelings if it happened due to my query i think its because of my wrong way of expressing the subject.I didn't mean anything like that.sorry for the trouble.
Didn't hurt my feelings. I just choose to ignore deadlines that I'm not being paid to adhere to.
David Simpson, PE
