More political than technical.
The 'local' levees were not designed to withstand impact from barges, of which there are many.
No one seems to have authority or budget to seize and secure or dispose of derelict barges.
Some landowners would not allow access to the dry side for maintenance. Yeah, I'd have thought eminent domain would take care of that, but in Louisiana, apparently it doesn't.
There was disagreement about who was responsible for maintenance.
There was no money for maintenance.
The only strictly technical failing that I see is a lack of structural redundancy in the levees. The "I-walls" are constructed in segments, basically like tilt-up panels, with water seals but no structural linkage between them. A barge hit tilts just one of them, producing two notch weirs, between the tilted panel and its neighbors.
The barge owner of course doesn't report an allision, and the landowner doesn't have money available for excavating the water side mud and re-erecting the panel, nor authority to do it. Those secondary levees were designed by USACE, which then assumed that maintenance would be conducted by local authorities, of which there are many. .. and the finger- pointing goes round and round and nothing gets fixed.
Mike Halloran
Pembroke Pines, FL, USA
