Rebuild Errors in Loft Command
  • Thread starter Thread starter akatulkhajuria
  • Start date Start date
A
akatulkhajuria
Guest
Hello friends, I'm trying to create the runner blades of the Francis turbine section. the problem which I'm having in creating the blades is that the loft command is no helping my case at all. When I try to loft two sections one is 2D sketch and another is 3d sketch which I've been projected on the inner side of the runner base by projecting curve method. The error I get every time I try to loft these two surfaces is Rebuild Error: Cannot make two planar end faces to cap the side sheet. This error is really bugging me out. I just made another runner by same method but can't made this one.I've put the image of the section below. Can anyone help me out??
