motorbiketocrank
Geotechnical
I have a project for planned aboveground water storage tanks. Subsurface materials primarily consist of SP soils with decent blows (varies but typically N = 10 to 20 range). Due to the depth of the stress influence zone, anticipated settlements are several inches.
To mitigate this settlement my design called for construction of a fill to apply a surcharge that will equal the pressure of the planned tank mat (w/ overlying fluid). Surcharge will then be removed after settlements have occurred and prior to construction of the tank. My inherent related assumption is that there will be no significant rebound in these cohesionless soils after removal of the surcharge load and that the final tank load will cause no significant settlement.
I'm experiencing some pushback, however, by another engineer who feels there will be significant rebound in the sands after removal of the load. I grant that the "elastic" settlement in sands is part permanent movement in the particles and part true elastic compression which would rebound (I view it like loading up a big pile of marbles). But my feeling is that the truly elastic movement and related rebound component is small. I've done some searches to find literature discussing the mechanics of settlement in cohesionless soils and rebound potential but haven't found much.
Does anyone have thoughts/information on how much rebound (i.e. % of total settlement) is likely under this scenario? Thanks.
