I was hoping someone would answer this question:
- Can you reassign 0-0 in CREO 10 after initially placed?
I came into my new workplace using CREO 7. I started an ordinate dim chain using two surfaces. I then realized I mistakenly selected the incorrect 0-0 lines to start my chain. I used NX and SW in the past - and there was a way to select either of the 0 references and reassign. All of the ordinate dims tied to the reference would refresh. I looked high and low for a solution in CREO 7 - and I just couldn't find anything within help or pecking around the menu options. I even checked YouTube.
So, we recently updated to CREO 10 and I assumed this would have been addressed. I mean if you spent a bunch of time placing ordinate dims - but then realize you need to re-reference one or both of the 0-0 references it would be nice to reassign without having to delete all of your work. I just started a new drawing to test this out. It seems like this still is not doable!!!! You can reassign placed dims in an ordinate chain - but no matter what I do to reassign 0-0 doesn't seem to work.
Is not reassigning 0-0 after placing them on the drawing possible?
I know it's a pain if the 0-0 surface changes in the model causing the ordinate dims references to be lost. I don't even know how to solve this if you can't reassign 0-0 given this case.
Maybe I'm just looking hard enough. Any CREO gurus that can help it would much apprecaited.
