I cannot believe that there isn't a block for an IF command or a high value wins block. All I want to do is only allow the highest value to pass through to the output i.e.
Input x and y. IF x>y then output is x but if y>x then the output is y.
I have been through the library and can't find anything but surely you must be able to do this using a Simulink block...
Hope someone can help...
