jcraft
- Mar 24, 2005
- 27
This is puzzling me so hope you can help. We have injection molding machines in our plant. We have a power analyzer hooked up to one to monitor the power consumption and stuff. Looking at the load profile for about 2 hours on this machine, it draws anywhere from 2.5 kw to 20kw depending on how the heater bands and pump motor are cycling. We have occasional peaks up to 25 kw for 1-2 sec. intervals. the data was taken at 1 second samples. The strange part is that during this 2 hour period about 4 - 6 times for one second the real power is actually negative. We looked at the actual data table and for one second it goes negative then it is back up to the standard kw. This is what we read from the data table for this one second duration. Apparent= 16.6kva, real power = -1.44 kw, Ractive = 16.54 Kvar and PF = -.09 ( Pf is usually .4 to .87). This is puzzling why the Kw would be negative and the PF goes into the negative for such a short duration. Any light shed on this would be wonderful. Thanks
