Reactor Containment Dome
ArunavaSinha
Chemical
Jan 1, 2016
8
Why the nuclear reactor containment dome is generally hemispherical in shape? Why not flat or circular?
In the case where the wall thickness is used to resist internal pressure, the wall thickness is minimized if a hemispherical shape is used. Of course, the true optimization of any large plant is to minimize cost ( while maintaining reliability and safety objectives), and it likely follows that the minimum wall thickness yields the lowest cost.
"Nobody expects the Spanish Inquisition!"
Pressurized Water Reactors PWR containment is a pressure vessel based upon a design basis accident DBA
That DBA is a primary or secondary coolant weld breaks which vents the coolant which converts to steam in a very short time. The containment is designed to hold that steam and water mixture. Then cool the entire system to a safe state.
The shape is the same shape as a gas bottle for the same reasons.
The demonstration reactors (<100 mWe) actually had sphere shaped containment structures for the same reason.
Hydrae
