Hi everybody, there is a fundamental question regarding the reasoning for the observed efect in the case mentioned below. I am unable to understand How does such a thing originate (the details of the - HOW and WHAT are in the question). So please read on and be kind to explain the observed effect mentioned.
There is a metal sphere which is cut and flattened at on one side and the flat side rests on a inclined surface.
The weight of the sphere is W = 20*9.81 N .
The sphere will tend to slide on the inclined surface as perceived. But the vetical wall on the left hand side prevents it froem doing so and the sphere is in static equilibrium.
The reactions generated at both the supports are R1 ( at vertical left wall) and R2 (at the inclined surface acting Normal to the surface) a shown.
The working out of the Equilibrium Equations the reaction R2 at comes out to be 305.23 N
( We do not discuss about reaction R1 here as it is not of our interest)
NOW THE REAL QUESTION :
The Reaction to any force is generally (to our general perception or natural instinct) equal to the force or a fraction of the force if the force is acting at an angle to the support ( the sine or cosine term).
But we never think of or perceive the reaction to EXCEED the Acting Force.
However in the example above the Reaction R2 (R2 = 305.23 N)is much more than the ONLY ACTING FORCE i.e. THE WEIGHT of the sphere (W = 20*9.81 = 196.2 N)
I've been wondering from WHERE does this EXTRA FORCE come from or WHAT GENERATES IT if the ONLY ACTING ( AVAILABLE SOURCE ) OF FORCE is ONLY 196.2 N.
What happens and how does the reaction turn out to be greater than the apllied force.
I couldnt figure out the actual REASON or PHYSICS behind this happening. Neither could I simply sit down just solving the problem Numerically and forgetting about the actual concept behind How the reaction turned out to be greater than the applied force.
So can anyone please explain tis phenomena as to How the reaction be greater than the applied force.
