TurbineBlade
Nuclear
- Aug 23, 2006
- 44
I am trying to understand waterhammer problem in a process system with focus on void formation and column separation. Can anyone suggest a good source of information/books?
The system is re-circulating water; fluid travel in a U-shape loop circuit, reaching at the highest elevation of 25 m from the pump suction, and finally discharge fluid at elevation 12m high. Both the suction and the discharge point are to atmospheric pressure.
1) I was told when the flow travels upward and turns horizontally, a column separation could occur?
2) Void formation could occur at the high elevation point.
