GB1000
- Oct 31, 2017
- 28
Hi, Apologies if this has been asked.
In relation australia tilt panel construction, I'm trying to find out what is the minimum reinforcement to use, there are a lot of companies which specify SL92 (292mm2) on a 150thk panel. however when I checked according to AS3600, the absolute minimum for 150thk wall is 375mm2 in the secondary direction. does anyone know anything different? Or do engineers just use a lower value out of risk?
